- Joined
- 2 Sep 2016
- Messages
- 18
- Reaction score
- 2
- Country
Evenin' all,
So my house used to have storage heaters, they've been taken out and scrapped and the separate mini consumer unit for them taken out as well. This has left a switch that does nothing on the wall and a piece of cable (stranded twin+earth, 7 strands on the live, 11.5mm across width of outside insulation) that has been routed across the house under the floor and I can get at both ends of it.
I would like to convert this obsolete switch into a socket as it's in a convenient place and there's already a metal backbox in the wall. The 32A ring main for this floor has 6 double sockets on it and is wired with solid core twin+earth, 10mm across width of outside insulation. I would like to add this new socket into it between two other sockets so that I don't have to touch wires in the consumer unit.
As far as I can tell from the wiki (https://www.diynot.com/wiki/Electrics:cable_types:flatpvccables ) the storage heater wire is 4mm² so has a higher current capacity than the 2.5mm² but am I allowed to reuse it as part of the ring main? Would save me a lot of time taking up floorboards if I could reuse it in situ...
