Salamander ct55+ single issue
31 Jan 2016
Hi all!
As part of a kitchen refurb, a new sink and mixer tap has gone in, I live in a bungalow so i connected a salamander ct55+ to boost the hot water pressure to the kitchen sink only and cold water mains.
Pump is working fine apart from the range of the pump before the pump is activated which is too hot. Once the pump is on I can pull the mixer to the cold and it gets a little cooler then any further the pump shuts off. It's still too hot.
I was wondering if I can manually alter the range of which the pump activates? Don't really want to drop the temp of my hot water cylinder.
Any help would be fantastic.
Phil
Moved from "your projects"
See http://www.diynot.com/diy/threads/share-your-diy-projects-with-us-no-queries-please.74081/
Mod
