Nope, you have a negative head pump (universal) therefore whatever the pump is feeding must be neutral or negative head. Therefore you need a universal (negative) head pump to replace it.Thanks - any idea if the Stuart Turner 3.0 Bar Twin Impeller Positive Head Shower Pump 46416 is a suitable alternative for the SALAMANDER PUMP RP100TU?
Well, I'm not sure....the outlets/pipework are actually below the cwst.....the showerhead by maybe no more than 30cm. I think the plumber put in the salamander RP100TU because of low flow. I would be interested in buying your ST pump but I honestly can't work out if it's what I need or not....Do you actually need a negative head pump, are the outlets/pipework above the cwst?
Thanks Madrab,Nope, you have a negative head pump (universal) therefore whatever the pump is feeding must be neutral or negative head. Therefore you need a universal (negative) head pump to replace it.
You'll need a Monsoon U3.0 bar twin impeller. Can't rate ST highly enough.
Plumbing may need a bit of fettling to get it all to fit.
No it is the standard one not universalsjmac,
Is the Stuart Turner pump you have for sale a:
Stuart Turner Monsoon 3.0 Bar Twin Impeller Universal Shower Pump - 46410
I think this is what I need.......
