Salus RT510TX mind of its own
7 Nov 2008
Hamilton, Lanarkshire
The instructions for this are straight forward enough. However, the damn thing keeps going up in temperature irrespective of what I set it at. Does anyone have the same issue with this thermostat? And if so, any solutions at all?
Many thanks in advance,
Kris
you have to select manual mode and set it to what temp you want and have to leave it in manual mode or the programmed temps will over ride what you have selected
Hi kristal17. Just seen this thread, as I had a quick search, my salus rt520 has started doing the same this evening. Did you manage to get it sorted??
you really should start your own thread as per the site rules, for very good reason your problem might not be the same, if you want the correct advice it is easy to start your own thread
