Discovered a small leak coming from the domestic hot water microswitch area, removed microswitch from valve housing & the leak is seeping from pin, I tightened nut up but its still persisting. Q: Is there an o-ring inside the valve assembly that I can replace or would I be quicker replacing whole valve assy? Dont have the manual, so any part numbers would be greatly appreciated.
Cheers.
Cheers.
