saxo vts
16 Jan 2006
Newport, S Wales.
1997 citroen saxo vts,idle speed will fluctuate when the engine is warm almost like a miss,heard of stepper motor problems on these so i disconneced the multiplug to it and the engine continued to run and didnt stall,anyone had any similar problems with one or have any data available to test resistances? plugs and coil pack have been replaced recently and i have cleaned out the throttle body
The stepper motors fail very often on all Pugeot`s and Citroens, get it changed and all should be well :)
Coolant temp sender is another one to look for. Cheap and easy to change
i did check the resistances on the cts on the weekend and it checked out ok,as suggested i reckon the stepper motor could be the culprit
cheers
