Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
We have a window with scratches on (were there when we moved in). I know you can can scratches out of some plastics with abrasive cleaners. Is there a way I can 'polish' the scratches out of the glass?
Jewellers rouge is probably the only one you will get anywhere near with but it'll take about three hours of constant circular rubbing and the result will be a clear but dull patch, but no scratch.
Give it the 2 meter rule, stand back 2 meters if you can't see it then live with it if you can, replace the glass
If the scratches are deep enough to feel with your fingernail (e.g. someone with a diamond ring, or the windowcleaner dropped his rag on grit) then you will grow old before being able to polish it out. I used a windscreen scratch removing kit with an electric motor and only managed (as skybluescooby says) to end up with an annoying dull patch instead of the shiny smooth finish I hoped for.
but many years ago, the new,rather arrogant and pompous Mangaging Director of the large building firm I was working for, called me into his office.
The building was made from precast concrete and over the years, the acid from the concrete (when it rained - very common problem some years back) had eaten into the bronzed double glazed window panels that adorned his office.
"I want you to polish those windows with Jewellers Rouge and a buffer pad" to remove those marks" said the MD. He then picked up this B&D drill with a small circular obital buffing pad attached to it. "I'll show you how to do it".
Now as hopefully most people know, when you use one of those, you should only apply it at an angle and use only the edge of the disc to buff with.
Not the MD. Straight onto the glass with the full flat face of the disc.
After I pulled him out of the now totally smashed £300 (This was about 1982!!!) bronzed unit, he rather shakenly said " I think we'll just buy new units shall we?"...
