- Joined
- 4 Jun 2016
- Messages
- 47
- Reaction score
- 1
- Country
Hello forumites,
I'm renovating my property currently and wanted to insulate what is going to be the media room floor and also bring it up to the same level as the rest of the house. This room used to be the garage, hence the floor height difference, and that's why the floor is sloping a bit as well. It is concrete.
The minimum depth is 200mm on one end and goes to 240mm on the other end. The size of the room is 5m x 3m with the slope being on the small dimension, i.e. 40mm drop over 3m.
I was thinking of placing rigid insulation boards (e.g. celotex) 130mm directly on the concrete, perhaps with a dpm laid down first, and then screed on top of the boards, so the screed will be 70mm minimum and up to 110mm on the deep end.
Does this make sense? Could there be any issues with this arrangement? Is there a better way?
Thanks!
Thanks!
