sealing compression fittings
4 Mar 2008
Devon
Hello,
I've been revamping my bathroom and have used some 15mm compression fittings under the floor which is to be tiled. All the joints are fine with the gravity feed system, but I want to add a combi boiler at a later date. Is there something I can use on the olives of the joints, just to make double sure there won't be any leeks with the higher pressure?
Thanks for any advice.
Adrian
Hi there,
Theres a few options.
Jointing Compounds, Boss White / Blue, Hawk White, or another alternative is Loctite 55 string.
Rico
your asking for trouble having a comp fitting that is not readily accessable, remove and replace with solder fittings.
