Sealing crack in concrete floor with no time
11 Jan 2011
Hertfordshire
I need to get some vinyl flooring down before christmas. It's going to be loose laid and may come up again in the new year to screed underneath.
Problem is, on pulling up the carpet the underside was damp above a fairly big crack in the slab. It's uneven where the crack is so needs to be chiselled out a bit and levelled.
I need to try and seal and level this on the cheap and in a day. I haven't time to put down liquid dpm. I was thinking of chiselling out a fair chunk of it, fill a little bit with a bit of screed and then put black jack or roof waterproofer on it then screed over.
Thoughts?
If the idea is to make the floor presentable for a few days then dont do anything else but clean the surface and flop down the vinyl sheet - come back in the new year with pics and more info.
If damp is penetrating the slab then it needs investigating.
If your local flooring wholesaler can supply you F-Ball Isolator, you may not need to fill the gap or screed in the new year.
