I need advice on an old concrete floor.
The floor meets the wall below the damp course.
There's no modern membrane up the wall, instead there seems to be a 1" wide vertical layer of fine gravel/sand next to the wall, then clay before the concrete starts?
(see pictures)
The gravel next to the wall seems to get damp through the brick when it rains.
The old tiles were layed with a small 1cm gap between wall & tile, which was covered by the skirting.
I need to know if it's possible to seal this gap, without causing damage (with expanding foam or something, what is the best method?)
Otherwise, I think moisture will come up from the gravel & make the space under new cupboards damp, like it did to the old skirting board.
Anyone got any experience of this type of floor?
(see pictures)
