If you want trouble free secondary circulation on a vented cylinder put an essex flange high up on the side on the cylinder side and pump away from the cylinder, the return can go into a surrey flange, no chance of pumping over and an air free supply to the pump.
I have fitted a pump on a secondary return at a large private school. I connected a by-pass pipe and installed the pump in that leaving the cylinder open vent un-restricted.
Why ? because the consultant engineer wanted it like that and did the drawings.
Later they hire me for a day to explain how a one pipe ladder system would/was have been installed after they make a giant fook up. 4 x 2" flows and 1 x 4" return, he assumed the flow would be the larger pipe
If its pushing water around a circuit and then back to the cylinder via a surrey flange how can it affect the open vent ? the distance between the pull of the pump and return water coming out of the surrey flange will be about 6 inches, please explain how thats going to pump up the open vent.
That wouldn't work. Why? Because the bottom tail bit of surrey flange is too close to top of hot outlet and may be cool as it is running around with no draw off.
If piped correctly, pump should be on return pipe toward an Essex flange about 2/3 from bottom. That way, there should not be any air getting pull in.
It is not a pump, it is a circulator and design to move water not pressuring it up.
