Seimens SE64a630 problem...
3 Oct 2008
Lancashire
Hi all,
I have the above dishwasher that has given good service for the last 2 years. A few days ago all I could hear was what turned out to be the water impeller. Im not sure if its trying to pump water out but the pipe isn't blocked as i put some water into the trough and it pumped it into the receptacle i had waiting on the end of the waste pipe.
I have done full power on off resets to no avail, i dont know if its trying to finish a cycle or start one but all i get is the impeller spinning in a little bit of water in the trough. Any suggestions would be appreciated.
Martyn
Firstly reset the appliance if it still does it check that the base is not flooded.
hmmm....thx 4 that dialacowboy.
On a more practical theme, it would be very difficult to get the machine out as it is fitted in between other cupboards. I have determined that, after finding how to reset the machine the impeller has now stopped and i can hear a sensor tripping for a few seconds before all noise stops. This now lends weight to the water sensor idea and i would appreciate any ideas as to how i can, if possible, clean the water out from the unit without getting a joiner out to remove the unit from its housing.
thx again.
Martyn
