Self leveling compond for wooden floor, suggestions?
2 May 2006
Glasgow
All, ive got a wooden floor in a coridoor (1.3m wide, 6 meters long)that leads to a small laundry room. Top floor of a 3 story block of flats, 1880 built stone teniment.
Theres 12mm (or there abouts) ply in place to level of the floor but there is still a noticable slope to one side (the outer wall), the drop is maybe 15-20mm.
I want to level this off so i can tile (or some other finishing) it and i'm looking for suggestions about the right approach etc. So far i'm thinking that a self leveling compund is the way to go, i've looked at Mira-Xplan
http://www.pureadhesion.co.uk/category/38/self leveling compound
Does this sound like the right way to go? are there any better/more suitable products out there? is this appraoch ok for wooden floors with a plyboard cover?
thanks
e
what sort of wood floor is it? if just standard floorboards on joists and not solid floor layed into adhesive i would go with plywood and seal all gaps with caulk to protect from moisture and then leveling compound. MUST BE FIBRE BONDED! try uzin or f-ball for product as about best on market. make sure you use flooring grade plywood and prime with correct primer.
the floor is standard floorboards (the origional ones far as i can tell) on joists. There is a layer of 12mm ply ontop at the moment.
mattysupra, some questions.
1. what is flooring grade plywood and where can i get it
2. which uzin / f-ball products should i be looking at and more importantly where can i get them for retail, i'm a diy bloke with no trade account
thanks in adance
e
just wrote a paragraph on how to do it but lost it on this new crap internet explorer i have downloaded. do you know how to send personal message so i can give you phone number to tell you how to do over phone and if anyone else reading this wants instruction on how to do it i will post new subject on it.
mattysupra, you rule!
better to post a new subject on it i think, i cant be the only person in the Uk with an old flat and wonky/sloping wodden floors othere will no doubt find the info useful.
thanks again for all your help, very much apprechiated.
i followed mattysupra's instructions in this and his other post, worked a treat :)
simple really isnt it. Can you do me a favour and post that reply in ' how to level a very uneven wooden subfloor' for me so other people can see and maybe who supplyed you products for other people to benefit! thanks mate. any more info you need , you know where to find me.
Matty, hope your still about. I'm just about to do the same thing. I have a living area thats a 1st floor. It has Ply and has been joint so there are no seames. I want to put polished concrete on it. I have a product but need a compound first that allows for abit of movement (I hope theres none!). What would you recommend?
Cheers
Roy
