Hi all,
I am looking to build a shed with power, using an existing power source - but have a couple of questions over the current wiring of the shed power feed as I am fairly certain its not correct (I moved into the house about 6 months ago and this was the wiring in the house).
N.B I dont use the power at the moment - its switched off at the consumer unit as the current shed isnt water tight. Part of this plan is to move the shed location as part of wider garden landscaping work.
Current setup
- 32A Feed from House consumer unit (2.5mm wire) goes to an external wall (about 10 metres away)
- From the external wall it was been housed into a plastic casing which is clipped to bottom of the fence
- This runs about 15 metres to where the current shed is and feeds both lights and 1 double socket
Proposed setup
- Install a WP junction box where the current cable goes outside
- Connect to SWA cable to existing feed and run in a trench to new shed (Could someone confirm recommended trench depth?)
- Run SWA Cable into Shed (exact distance yet to be confirmed but say 15 metres as the current set up)
-Connect SWA to new Garage CU (Like the following: http://www.screwfix.com/p/bg-garage-kit-enclosure-5-module-ip55-40a-rcd-dual-6a-32a-mcb/68849)
I would use the Shed unit to run deck lights, maybe have 1 or two double sockets and a shed light.
As a proposal does that sound viable? In my previous house the electrician took the power feed directly from the outside electrical box and ran the power feed from that to a out house I had but wondered whether this would be required in this instance given that power goes to the external wall at the moment anyway?
Be keen to hear your thoughts all.
Thanks in advance.
Current setup
Proposed setup
Thanks in advance.
