Is it possible to use sheet plywood as flooring? I'm thinking of using exterior grade plywood to replace half the flooring in a batghroom, where it has been water damaged. It currently has floorboards, several of these have sunk in due to a long term water leak, so was thinking of removing these 4 or five rows of boards and replace it was exterior plywood. If this is ok to do, what size should i use, 12mm or 18mm?
thanks in advance
thanks in advance
