Should I use washers when screwing plasterboard to studwork?
13 Apr 2011
Leicestershire
I am going to fix 30mm insulation and then 12.5mm plasterboard to my rafters using 80mm screws - do I need to use washers to stop the screws going through the plasterboard? :?
no
as you tighten, the screw heads will start to pull themselves into the face of the board. Then you stop screwing. You have to press the board tightly into position first.
I prefer galvanised clouts, they have a large flat head that gives good support rather than a small cone from a screw. It's just simple mechanics really.
Simple mechanics dictates that a screw is less likely to move independently of the board as the board or the joist moves. Which is easier to pull out with a claw hammer - a screw or a nail? The action of a moving board on a nial/screw is similar to the action of a claw hammer
Screws are standard for over a decade now. BG* only specify screws, as does any modern architect's spec.
* That's 'British' Gypsum 8)
