Hi, wondered if anyone could offer an explanation of why this happens?
The ceiling mounted switch for our 9kw shower began to get stiffer - not switching off cleanly and yesterday I heard what I assumed to be some 'arcing' in the switch. It was hot to the touch and beginning to smell a bit, so I swapped the switch for a new one.
The neutral wire on the feed side had clearly been getting hot - it was held securely by the screw but the insulation had charred and the copper strands were blackened. I cut this back before re fitting.
Is the load too much for the wire? We're just starting to use the hotter settings on teh shower - using both of the elements. Why does it just happen at the switch? is it just a by product of the ceiling switch failing? It has happened before, but probably 2 or 3 years ago without any re occurrence.
Help? View media item 85653
