Shower curtain onto a sloping ceiling-- Ideas Please
29 Nov 2011
Staffordshire
I've just bought the property and the bathroom appears to have had a shower option but no apparent curtain (it probably explains the stained paintwork in the lounge ceiling below)
As you can see I have a sloping ceiling, how would you provide a solution for a shower / bath options.
The ceiling levels out just out of shot of this photo
The other end of the bath is open (not against a wall ), so I expect the curtain would also need to wrap around the bottom part of the bath
Thank you in anticipation
Oh my, that's quite a setup. You could get a glass screen custom made to fit by someone like Kudos, with a second one attached to the side wall that folds over the bath when you're showering...
I'm ideally looking for a low(ish) cost solution as my pockets end when my hand is only half way in. Although I'm quite handy and can knock something up quite readily.
the rail you see is for the shower head as its central
the curtain will be at the edge off the bath and hanging into the bath
if you already know this apologies its been a long day :D
Thanks guys definitely food for thought there, I like the idea of the circular ring but it does look a tad small, i'll delve deeper :evil:
How about two hooks on the ceiling, cut and machine a shower curtain to suit with an eyelet each end to fit on the hooks.
