Shower doors have come off runners
27 Aug 2010
Londonderry
The curved shower doors wheels have come off the runner board at the top and the little curved notch is off at the bottom,can anyone help,the shower is a nIAGRA.
not entirely sure about Niagra make, but most curved doors I've come across, they just drop back in. You need to stand in the shower and hold the door just slightly higher than the position it would hang - make sure you hold it vertical. You should feel it slip into the frame, then you can drop it a couple of millimetres and it will sit correctly. You may need to try it a couple of times to get all four (2 up and 2 down) rollers in the correct place at the same time. Make sure you hold the door firmly the first time you try opening/closing it, because if it isn't seated properly it may fall off.
