shower enclosure
23 Mar 2005
hi, i noticed on B&Q web site they are having a sale on certain shower enclosures.....really interested but need some help first.
i have a tiled opening of 800mm square wide,with tray and waste already installed....all i really need is a 800mm shower door but there bl~~dy dear.
the enclosures on offer at b+q are only 760 wide adjustable upto 20mm for out of true walls.....but if i fitted a 20 mm strip of wood to walls either side,would i be able just to fit the door and frame without using the side panel?or do you need to use the side panel
Why don't you see if you can get extended jams for the enclosure.
Some manufactures do a standard 760 door with the standard posts but you get posts are extra deep to go up to about 820mm with the 760 door.
what they called exactly so i can do a search for these?
that was going to be my next question..."is there any method of increasing the frame size"
The door frame stays the same it's just the post which fit on the wall are deeper letting you fill up the space. They are called extended jams or wall posts. The door frame fits into the posts. Check shower enclosure manu web sites or I'm sure the shed will do posts too but you'll be left with the ordinary ones, recycle them or use as shelf supports.
A few years ago I used a Wickes door on an 800 tray. About £80 then and still looks fine (I do the landlord's gas certs!)
