My wife and I moved into our first house back in October. A couple of months later the shower gave up. This was a fairly old looking mira event power shower so has hot and cold feeds. I bought a new mira power shower for a quick swap and here the problems started.
On cold the shower works as it should, when turning it onto the hot for the first minute or two the shower struggles to pump out anything at a constant flow with it stuttering. After this you get a few minutes where the shower works as it should, that's fine for me but the wife isn't quite as quick and so suffers when the it goes back to wavering amounts of flow from the shower.
When we first had the problems I took the shower of the wall to check the feeds, I put a couple of tanks of water through the hot to see if there were any air locks but this didn't change anything. I also had two different plumbers over for some advice. The first raised the vent pipe but this didn't change anything. The other could only suggest that on the hot water feed valve we don't open it fully so it gives a more constant flow albeit restricted. The only other suggestion has been to raise the water tank in the loft, this is a coffin style tank so plenty of scope for this.
Before I embark on this which I hope would be a solution does anybody else have any suggestions?
Our system is on a fire back boiler with the hot water cylinder on the ground floor and water tank in the loft, feeds to the shower come from the loft.
Many thanks
Many thanks
