SHOWER PUMP, CAN I USE NEGATIVE PUMP WITH POSITIVE TANKS
13 Jan 2010
Hi all,
I ordered a techflow positive pump and the supplier sent out a negative. its twice the price, and in the future i plan on converting the loft.
my question is can i use the negative pump even though its a positve tank?
thanks
mark
when u say positive tank I assume that u are refering to the fact that , the storage tank is higher than the shower out let , were as they have sent you a shower compatable with a system were the shower out let is higher than the cold tank there fore you would require a manual start up for the pump , if so I dont see any reason why it cannot be used , it might even come with the relevant flow switches any way ????
