Hi, im new here and have a query regarding my shower pump.
Its a Showermate 1.4 bar twin. basicaly it supplies water to two showers in the house,one upstairs and one down stairs. if i select either of the shower controls to full hot or close to full hot the pump cuts in and out but as soon as you return the heat control back towards the halfway position the pump is quite happy. It is also happy if you select full cold too. I called the company that makes the pump and they reckond it was because the water temp on hot water cylinder was to high. As instructed its been turned down to 58 degrees but still no change.
I recently had a new diverter valve replaced as old one was stuck on hot water,no heating.
Sorry if my explenation is a bit vauge but any help would be great before having to call someone out or replacing components.
