I have just moved into a 3rd floor flat.
The shower in the bathroom is of a mixer valve type and is fed via a hot water cylinder tank and cold water from the tank in the loft.
The flow rate from the shower is quite low and i wish to improve this.
Option 1 is to put a shower pump with a twin hot/cold to the pipes feeding the mixer.
Option 2 is to put a single feed pump in between the outlet of the mixer and the shower head.
Option 2 to me seems like an easier option, but what is the best and normal method.
What size of pump would be suitable
Thank you very much
Thank you very much
