Hi lads
Looking at removing the bath and fitting a shower tray
Few questions for you
Going to remove the bath and do away with it and fit a shower tray
Do i just fit a isolation valves and blank hot and cold water supply for old bath under the floor
The new show tray waste is going to be plumbed in to the soil pipe (is this fine as it will be below the inlet of the toilet , its only under 2 meter of run from tray to soil pipe and i am going to use the hepvo connection as there isn’t a lot of room but enough for a run for the waste
Also is there any regs to having a waste pipe and water pipe behind plaster walls
Thank you
Thank you
