I am fitting a shower and have been given contradictory advice by two plumbers. One says run it in 40mm and one says run it in 50mm.
From the shower waste is 1m to to the first vertical drop of 100mm. The next run is 3.5m to the next vertical drop of 2m into a WC waste.
What fall would I need for the 3.5m run?
Clearly 50mm is better than 40mm.
Is 40mm sufficient for the whole of the run?
