- Joined
- 23 Jun 2019
- Messages
- 15
- Reaction score
- 0
- Country
Can anyone advise on the best sheet material for forming a 2.8m circle to form a concrete base for a patio. In truth it will actually be ring, essentially a small retaining wall which I can fill with sub-base, so a 2.4m diameter form inside the 2.8m, 100mm above the current grade and about 150mm below without having accurately checked my levels yet.
My reason for not just doing a whole circular base is that I want a permeable patio to avoid water logging in the remaining garden, so will use a permeable bedding course and polymetric sand for joints. I have never built anything out of bricks so this seems the best route rather than building the edge up from a footing. The ring will be capped by decorative edging pavers and backfilled with soil for flowerbeds.
Would a 5.5mm ply survive the load supported by stakes and partially supported by the ground? It'll be about 0.4 cubic metres of concrete going in to it in total.
Reusing the forms would be nice but not essential as I'll have another curved path edge to make in a similar vein.
