Siemens Slimline Dishwasher - Anti Flood - Pumping out
22 Jul 2013
My Siemens Slimline dishwasher has been in storage for 8 weeks and now doesn't work correctly.
Initially when switched on it pumps out the old water, then it starts to fill. If I open the door I can see fresh water coming into it, but it is still pumping out at this time. I can hear it pumping fresh air out if I open the door. A bit of research indicates this is probably some water getting into the wrong place from the move and the Anti Flood device kicking in (or a leak causing it to kick in). The problem is, I'm not sure where to look.
The kick board on the front only reveals a plastic front, which has nothing behind it. I assume I need to remove the sides to see anything interesting?
I can't find the serial numbers, but have linked to pictures here:
http://s784.photobucket.com/user/cuthbei/library/Dishwasher
It is an SF24T558GB
Also, it is not filling at all, just pumping out.
