the heating works fine , but when the DHW is turned on it runs warm then just cold, any idea what is wrong , I have put new kit in diverter valve , could it be the water rate adjuster?
Hi Tony, I have the same problem with my boiler like rayatnpt. I can`t find a good service man. Diverter valve has been changed, and is still not working when heating is off. Diverter valve switch works when heating is on. I checked microswitches, they work. Do you have any idea what is this a problem ?
