shower water starts to go cold for approx 30 secs when boiler re-lights is the temp transmitter u/s also does anyone know where i can get a manual from please
Run heating for an hour and check the temperature of the rads right next to the valves on both sides and then the in the middle of the 2 points that you measured or felt. If the middle is colder than the sides, your problem is likely to come back.
