Sometimes refuses to fire up when mid-cycle in central heating mode. Can get it started by slapping the right side of the boiler. Any suggestions for a permanent cure?
Our usual RGI has tried a new PCB but it made no difference. I think he also replaced the pressure switch without success. Next step seems to be getting an electrician to check for a dry joint somewhere. Any comments please?
