Single or double panel rads?
27 Mar 2009
Yorkshire
I need to replace my old radiators. So, assuming the btu of the following two radiators was the same, which is better..
2000mm single panel
or
1300mm double panel
Is it just down to aesthetics and how slim I want the rad, or does one use less/more energy than the other?
What do you have at the minute?
Opting for a type 21/22 may result in pipework alterations.
Longer single spreads the heat into the room a bit better but eventually it should all equalise either way.
