Hi all,
I'm currently converting my (attached) garage. My plan for the long external wall is: -
My issue is how the battens should be attached to the wall - I would require extremely long fixings.
My only other thought is to create a stud wall instead of the battens.
Does anybody have any other suggestions of how its usually done?
Thanks.
(Existing external single leaf brick wall)
Breather membrane
100mm Celotex (sealed to form vapour barrier)
50mm tanalised softwood horizontal battens at top and bottom, plus vertical battens to coincide with each lining board joint
Thanks.
