sink drain probs
13 Jul 2006
London
hello
I have a prob with my sink
the plug hole is leaking. I pried it off - didn't take much - so I could clean it up and put on new sealant - the metal whatnot below that goes into the drain wasn't even touching the sink - clear air all the way round. Looking underneath, there doesn't seem to be any kind of fitting to attach it to the sink - it was just pressed up against it - surely some mistake - should tere be a bolt somewhere? can't see how it works?
any advice gratefully recieved
mark
Hi
In the sink there should be a screw from middle of grill going into the body of the base. This needs to be tight to clamp the sink.
The complete thing is quite cheap and easy to fit, buy new from any plumbing or DIY store.
Hope this helps
yes it did help thanks
I was dreaming about it and realised that the plug in the half sink had a straight rod in the centre and in the full sink it was threaded - yes the screw had attached itself - now all reattached and no leaks and nasty smells
but dreaming about plumbing probs - i think i'm in need of a life!
thanks again
mark
