I have purchased a house built by Hassel Homes roundabout 1980. It uses the Dot and Dab method of fastening the plaster board to the breeze block. The plasterboard seems to have a final finish on top of the plasterboard which is not plaster because its white. I was told this was a common method used by Hassle Homes because it was cheap and saved plastering. Unfortunately some of this finish is lifting away from the board in quite large pieces (appears to be like thick card). I am removing the loose finish and filling the gaps with Uni Bond filler and then intend to have the walls skimmed with plaster. The plasterer says he cannot guaratee that the plaster will stick because he is unsure if the original finish will react with the plaster. Any information or advice is welcome
