Sky TV Aerial - Mounting Plate
11 Jan 2010
Leeds
Hi all,
I've recently run a cable from my sky box to my bedroom so I can watch sky up there. I have a magic eye and a remote and all works fine.
We need to redecorate the room so i've been thinking about installing a mounting plate on the wall where the cable comes in (just to tidy it up). I can chase the cable into the wall and bore out the mounting plate.
Any ideas which / where mounting plate to use please?
Many thanks,
Daniel
Id advise against using a wall plate with the magic eye system as its an extra joint in the cable. However if you really need to use one would reccomend using the threaded F type of socket as it will make a better connection than the traditional belling lee type which i find work loose out of the wall sockets.
The other option is a brush plate where the cables just pass through the plate with no joints.
