I took off a rad the other day so that the plasterer can get in behind it to skim the walls, all ok no probs so far.
This evening I disturbed the pipe to the rad valve whilst removing the skirting board and now I have a small leak from a compression fitting which was used to extend the pipe when we put on a bigger rad a few years back.
Anyway this leak is about 12" before the TRV and is leaking at the rate of about 9 drips a minute (540 per hour i'd assume, providing it doesnt get any worse)
I dont want to try nipping the fitting up any more, (it is 8mm microbore) in case I worsen it.
My question is, does the system need draining down to fix the fitting? or is there anything I can do to avoid a drain down, as I would rather a plumber did this.
It is a pressurised combi system (Baxi 105e, running at just over 1 bar)
thanks in advance
thanks in advance
