Small leak
11 Sep 2007
I hope someone can advise.
I knocked the compression valve on a cold water pipe causing it to leak slowly around one of the nuts. I've replaced the whole valve but it now leaks from both nuts (so to speak) :roll: They are both as tightly screwed as I can get them without shearing.
Should I just wodge up the whole thing with tape or is there a better answer?
cheers
Compression joints can leak more if they are overtightened :cry: Undo it and try a few turns of ptfe over the olives.
The copper on to the stopcock at both ends are not home, remove it and make sure they are seated.
