Smeg LSA6049X
27 Feb 2011
Does anybody know how to perform a factory reset on this ? I think the PCB is on its way out. This dishwasher functions intermittantly. I get random error codes that are not documented in the manual.
Thanks in advance.
Error codes are only a guide & as such can be misleading. Invalid error codes may be a sign of pcb failure but not all error codes (or possible causes) are covered in your user manual. What symptoms are you experiencing? Does it (or does it not) fill, rinse, wash, heat, drain, dry? The more information you supply the better your chances.
Hi again, thanks for the speedy reply.
The dishwasher starts as normal and I can hear water being taken in, then after about 3 minutes I get 5 beeps and the the lights light up to show a error, the lights that light up are the last three phase lights (there is six phase lights in total).
Thanks in advance for any help.
So the machine pumps out, fills, then stops with water in? You never hear the wash motor running or trying to run? The next time you try & start a program does it evacuate the water then do exactly the same thing over again? You may have a jammed wash motor impellor, defective motor capacitor, faulty motor windings, a wiring issue, or the pcb is history. When it stops & the 3 LED's are lit which ones (if any) are flashing?
