Hoping and praying someone can help me with the mess my boiler is in!
Its a potterton Puma 100 and we have been having trouble for months.
A week before christmas the pcb board burnt out in the top left hand corner, we had this replaced then a month later the power to the boiler went again. Got the power restored and called the plumber in have a look at it. As it still was not working right, the outlet pipe was gushing out and so we were losing pressure he repressurised the expansion vessel and said we needed the pressure relief valve replacing and also the pump had been previously fitted upside down! he turned this around. He said if all that didn't work the heat control thermostat on the pipe could have gone. So we had the pressure relief pipe and the two thermostats on the ch pipe replaced.
All this time the boiler had a leak some where, we managed track it down to the heat exchanger. This has now been fixed we also had to replace a broken cooler fan too but when the boiler was all put back on the switch that controls the central heating is not working, the boiler standby/on switch is but as soon as you switch this to on the heating fires up although it is only heating up two rads, but we thought at least we finally have hot water after all this time, however now the hot water is getting hot but it is only coming out of the tap a bit and the red led light that comes on when you call for hot water doesn't always come on.
So what could all this be? pcb board again? or hw diverter switch or both? or something completely different.
Im so fed up of this boiler as soon as I fix one thing something else goes wrong with it, it was only installed new in 2000. We are ready rip it off the wall. I have a two year old so I need the hot water and it was bad enough trying to survive winter without heating or water.
Thanks for reading, sorry its such a long one.
