It is possible to remove old windows from my softwood frames and replace them with double glazing units. It is not an option for me to remove the wooden frames, because although old frames they are in fairly ok condition, and it is the MAIN feature of the house(bay windows). The windows have small square windows in a metal frame within the window itself. At the top I have square windows with colour glass in shape of flowers.
The current window(s), are being held in by what I think are strips of lead pushing the windows together at each side in all four sides.
I was hoping to remove the window, rip out the lead strips that hold it in place and measure up a double glazed unit of the same size, and then cut the wood from the inside to cater for a double glazed unit thickness, and place some kind of bead on each end to hold in, with some glazing foam between. (can this be done?)
I am not so sure now, it looks like a huge task. If I was to take out one of the windows could a standard double glazing company install a double glazed panel into my existing frame. I realise the glazed unit will be heaver and thicker, and some cutting will be required, but I don't really care if it looks bad from the inside as long as the outside look ok. Any ideas of costs also.?
Sorry for the vague descriptions, I have limited knowhow of windows/frames.
Thanks for help in advance.
