soil position in floor
17 Feb 2011
Devon
Hi all,
can someone please tell me the correct distance to set the centre of the soil outlet in the floor to take a c/c pan and cistern at a later stage of the work. Also I need to connect shower and basin waste each side of pan is there a multi-quik with inlet(outlet ) each side??
The position of the outlet varies between WC suites, so it's whatever the manufacturer of your chosen suite specifies.
Sometimes theres even enough room for a straight pan connector running into a 92.5° soil pipe bend.
A short boss pipe, something like this:-
near the top of the soil pipe would allow connection of the wastes, but it would have to be low enough to allow for the length of the pan connector inside the soil pipe.
A boss on the pan connector itself would probably be too high for a shower waste to run into anyway.
Many 'S' trap type C/C WCs are 90mm from a finished wall to the centre of the outlet, but it's far better to buy a complete C/C WC, cistern & bent WC connector, measure it just to get it correct.
Any waste pipe in a single stack SVP system should be fitted directly to the vertical SVP. Check out any plastic manufacturers installation instructions.
