Soil stack advice
Thanks that may just work. I think it would be a standard branch straight in to one toilet then a Y135 below with a 45 bend. What do you mean by backwash?
Ok thanks. The method of using a Y135 below one normal tee should allow me to run the pipe on the wall on the left as you look at it which will make things easier to boss.
Thanks I'm still a relatively inexperienced plumber. Guessing I'll need either a single or double ended 45 I'll see how it looks tomorrow. Thanks again
135 branch 45 bend to take that to going up square then a 90 to pick the toilet pipe up I think it will work out
The 135 tee looks like it will work. I just need and offset to go in to it that will bring the pipe back to square. What offset would this be. A standard 45 degree offset won't do it.
