did you find a good forum in the end. I've always got decent advice from here but solar seems to be a whole other thingHi i am surprised we don't have a dedicated Solar Panel forum here, anyone point me to a decent one?
I am looking at having a system installed and want to discuss what i may need ie best panels inverters etc thanks.
thanks for the links, I think they should. That being said it's a pretty massive topic as i'm just finding out, and opinions are subjective.They should just create one shouldn't they? Lots of youtube channels that you want to check out:
Not so many for UK but try this:
www.batterymegastore.co.uk
Funnily enough, my brother was looking at a Victron inverter as it does most things and removes the need for additional gear. I see this as good and bad. It's great from a compatibility POV but if it breaks then the whole thing will need replacing.It is a big topic but it may be worth just sticking to one brand. For instance Victron have a pretty active forum:
And they supply most (probably all) the parts you need with the necessary protocols to connect them all. If they don't support a configuration you may want to reconsider whether you should run it. If your spark can't deal with Victron you may want to find another one.All Posts - Victron Community
community.victronenergy.com
But then again, if you don't want batteries (at all) then there may be cheaper options.Victron Energy Inverter Chargers: Reliable Power Solutions
Victron Energy inverter chargers provide reliable power with true sine wave output and adaptive charging—perfect for off-grid and backup power systems.www.batterymegastore.co.uk
I’m thinking of having them.I agree that a forum on here for Solar Panels would be good. I've just had a quote for fitting them on my house and with the increasing costs I wonder if I should spend the money. I trust this forum to be honest and not controlled by one company.
For Solar thermal you get 70% vs 25% efficiency with PV, which means three-times the panels for the equivalent PV power, so sounds great if you're short of roof space, but OTOH you must pay for un-vented tank with possibly multiple coils which is expensive and then to stop it scaling up and needing to replace it after 5-10 years you then need to consider a water softener which is not only extra money but you have to fill it with salt once in a while, store said salt somewhere and (literally) bags of hassle. The one (really big) benefit is that your energy storage is otherwise cheap and environmentally friendly (water), - even if somewhat short-term - and it's flexible, because you can put that tank in an attic, which you probably don't want to do with LiFePO4 cells.I’m thinking of having them.
I can’t decide whether to have solar electric, with or without batteries and or solar thermal.
