Solar Panel: Inverter Shutdown and Static Generation Meter Reading
2 Aug 2025
I have solar panels installed on my home. The reading on my generation meter (Geo Emlite M15) hasn’t changed for 6 months, i.e. since February. The meter displays a steady green “STS” light and a flashing red “NWK” light. I’ve confirmed that all breakers and isolators are switched on. The solar inverter is completely shut down. However, when I turn the breakers off and then back on, the inverter powers up briefly, displays some data, and then shuts down again after 30 seconds or so.
Could you advise what the issue might be and who I should contact to resolve it?
Thank you
Sunny Boy. Thank you.
The inverter should show a fault code. Post that code here so I can see what that code relates too.
Edit: I should have said. On start-up the inverter carries out a number of self checks. It then checks the systems AC and DC. If a problem is detected the inverter will either shut down or sit idle displaying a fault code. There are several things that you could do to see whether it is an inverter or system fault.
As an aside, I don't think a German company does itself any favours by giving its products a name which makes them look like Aliexpress specials...
