Solid fuel heat source & pipework
11 Jan 2013
Durham
The Wiki has answered a few questions but can't find an answer to this particular query....system is still in design/mulling stage so no desperate panic here
If your heating/hot water system incorporates a heat store connected to a woodburner, does the DHW pipework between heat exchanger and taps/shower/other end use have to be copper?
And if the answer to that one is a YES, would a tempering valve after the heat exchanger (set to 48 deg C) be acceptable as a 'control system' (so that plastic pipework can be used from valve plus a metre or so to end uses) - this would be as well as the overtemp dump valve which I can't remember the proper name of but if water in primary circuit/heat store starts boiling said valve opens to allow boiling water to escape to safe drainage & thus permit cold water to enter the system to cool it down).
I'm not a massive fan of plastic pipe but getting a copper hot water feed to one particular location is going to be a bit of a mare.
As far as I am aware any open vented hot water system will never exceed 100C so that plastic pipe can be used.
Tony
Happy days- ta chap, physics seemed to indicate that but Part G is a tad opaque on the details :)
Its the primary pipework on the heat source where it should be metal.
Since the heat source is uncontrollable the expectation is that it could exceed 100 C although in theory that should not happen when its open vented as the water would just boil off.
But faults and blockages can happen!
Thanks again- yes the rough sketch so far is woodburner in the kitchen fireplace (which the gf reckons is begging for an Aga but she's no cook and neither am I so sod that), heat store in the alcove next to it as high as I can get it and linked with 28mm copper. Don't like pressurised systems, failure consequences are a bit high and in a house with a loft I can't really see the point.
