Hi
I want to strengthen my loft floor - don't want to do a full loft conversion but just make the space more usable and less unpleasant.
What we have at the moment: we're end of terrace, there are joists running (I think from memory) front to back at 3-400mm ish centres (I'm going from memory here). There is one (I believe) supporting wall runing side-to-side roughly 3/5 in from the front of the building.
Then ON TOP of the front/back joists are some more substantial beams - maybe 4-6 of them running from the party-wall side to the end-wall.
I presume if I want to strengthen the joists its the bottom ones? What do I do about the top ones?
Also if I go the sistering route and bolt/screw some 2x6 or 2x8's to the existing joists (with a lift at the ends to clear the ceilings) so I need to get full-lengths up there (how do I do that without removing the roof tiles?) or do I get shorter lengths and join them at the supporting wall?
thanks
thanks
