Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Not an electrician but separation between low voltage, (230-1,000Vac), and extra low voltage ( <= 50Vac) is 100mm or 4" to us oldies.
Having said that I've seen loads of speaker cables taped to mains cables in an effort to make them look tidy.
Conny, thanks for that.
I would not want to put speaker cables on top of mains cable incase someone puts a drill though both and makes speaker terminals live. But I do want to put both in designated safe areas so onow where not to drill. So just under 4" seperation works perfectly for me.
Thanks SFK
