    Dismiss Notice
Squeaking shell chair
Discussion in 'General DIY' started by ChetMaker, 7 Sep 2020.
  1. ChetMaker
    ChetMaker
    13 May 2018
    10
    Thanks Received:
    Country:
    I have a few of those 'shell' chairs. That's the model, but you can find dozens of variations - https://www.officesight.com/wholesa...k-plastic-mid-century-modern-shell-chair.html
    They start to squeak when I sit down. I tried to tighten bolts, but they're are too worn out. I'm looking for replacement for those, but I wonder what else can be worth trying. Applying WD-40? Trying to add some cushion pads between the screw and plastic or the metal part?
  2. Sponsored Links
  3. foxhole
    foxhole
    14 Mar 2006
    16,212
    Thanks Received:
    1,812
    Kent
    Country:
    Fixing them securely should stop the squeaks.
  4. conny
    conny
    30 Jun 2008
    12,625
    Thanks Received:
    552
    Suffolk
    Country:
    Slacken the bolts slightly and put some talcum powder between the frame and the seat. Re-tighten bolts.
    You may have to do this every couple of months.
    Alternatively slip a little piece of thin rubber in the gap and make sure fixings are tight as possible.
Loading...
Share This Page
